anna_arun
Jul 01, 2013NETGEAR Expert
NFS Path for Windows Application
Hi , I have to give a NFS path to my application to store data on to the ReadyNAS 516 . What is the default path to enter to access the path ? Tried /c/sharename ... Does not work . Had enabled NFS o...
Jul 02, 2013Guru - Experienced User
Of course you also need to have an NFS client installed on the Windows machine. It isn't installed by default.
