anna_arun
Jul 01, 2013NETGEAR Expert
NFS Path for Windows Application
Hi , I have to give a NFS path to my application to store data on to the ReadyNAS 516 . What is the default path to enter to access the path ? Tried /c/sharename ... Does not work . Had enabled NFS o...
vandermerwe
Aug 27, 2013Master
Realise this is a bit of an old post, but I have discovered that OS 6 behaves differently to 4.2.x with respect to nfs paths:
I have a Dune HD media player that is accessing video files on a Readynas Ultra 6 plus using this syntax:
nfs://ipaddressofnas:/sharename:/pathinshare
With NFS on OS6 on a 316, this syntax was not successful at reaching the relevant files.
The syntax I need to use is:
nfs://ipaddressofnas:/c/sharename:/pathinshare
For some reason the volume label is required, even though nfs is enabled for the share and access rights are identical to my Ultra6+
