anna_arun
Jul 01, 2013NETGEAR Expert
NFS Path for Windows Application
Hi , I have to give a NFS path to my application to store data on to the ReadyNAS 516 . What is the default path to enter to access the path ? Tried /c/sharename ... Does not work . Had enabled NFS o...
jmirabil
Mar 15, 2015Aspirant
I thought you solved my issues with this:
With NFS on OS6 on a 316, this syntax was not successful at reaching the relevant files.
The syntax I need to use is:
nfs://ipaddressofnas:/c/sharename:/pathinshare
For some reason the volume label is required, even though nfs is enabled for the share and access rights are identical to my Ultra6+
But my 316 Readynas on OS 6 wont take this syntax or anything close.. wierd---any other suggestions??? I'd like to use NFS ; I have SMB wokring, but NFS should be much faster....
and I am using a Dune HD media player, hence why I thought you had the exact syntax I needed...
I am asked for a
servername
and a
sharename
separately, if it matters...
THx!
I am asked for a
servername
and a
sharename
THx!
