anna_arun
Jul 01, 2013NETGEAR Expert
NFS Path for Windows Application
Hi , I have to give a NFS path to my application to store data on to the ReadyNAS 516 . What is the default path to enter to access the path ? Tried /c/sharename ... Does not work . Had enabled NFS o...
jmirabil
Mar 18, 2015Aspirant
You're exacttly right.. thanks! Dune HD player is working with ip address in top field, and /data/sharename in the second field - perfect. Works via udp and TCP, whether the NFS share is set to read only or R/W.
Incidentally this is exactly what Eric in Netgear Customer Support told me to do in a parallel inquiry - thx all.
