Enfreyer
Dec 29, 2012Aspirant
No Acces and System reset not working
Hey guys, I have annother extremely annoying problem. I unplugged my ReadyNas Duo v2 from its network to take it home to access my data locally. Now I cant access it. Not with direct connection ...
Jan 06, 2013Guru - Experienced User
This is a very unusual network config.
Enfreyer wrote:
I think the reason for the failed access was, that the NAS used 192.168.1.1 as DNS,
but 192.168.5.4 as own IP. Maybe the different adress ranges caused problems
while trying to access.
I now added 192.168.5.1 as second DNS and test it soon.
Is your router 192.168.5.1? Do you have a device on your own network which uses 192.168.1.1?
If you are using 192.168.5.x private addresses, then 192.168.1.1 shouldn't be configured as a DNS server at all.
