Enfreyer
Dec 29, 2012Aspirant
No Acces and System reset not working
Hey guys, I have annother extremely annoying problem. I unplugged my ReadyNas Duo v2 from its network to take it home to access my data locally. Now I cant access it. Not with direct connection ...
Enfreyer
Jan 06, 2013Aspirant
StephenB wrote:
This is a very unusual network config.
Yeah, I had to change my routers IP-Adress to 192.168.5.1 due to port forwarding problems (to
share my NAS via ftp online). It didnt work with 192.168.1.1 as routers IP. If I remember
correctly it was because of the IP of my modem (which was 192.168.1.1 too).
StephenB wrote:
If you are using 192.168.5.x private addresses, then 192.168.1.1 shouldn't be configured as a DNS server at all.
In the DNS config menu I can set in the first three lines "Domain Name Server *: ", and in the last
line I can set "DNS-Server (Domain Name Service): ". What are the differences? Is the last one the
adress for the internal DNS?
@mdgm: I try to find it again ;).
The Radiator Version is RAIDiator 5.3.5, but I'm very sure I installed something inofficial.
