Enfreyer
Dec 29, 2012Aspirant
No Acces and System reset not working
Hey guys, I have annother extremely annoying problem. I unplugged my ReadyNas Duo v2 from its network to take it home to access my data locally. Now I cant access it. Not with direct connection ...
Jan 06, 2013Guru - Experienced User
That would explain it. But you should be aware that your "modem" is actually functioning as a NAT router. 192.168.1.1 is a private address which cannot be routed over the public internet. Does your modem have more than one lan port? What model/brand is it?
Enfreyer wrote: ...If I remember correctly it was because of the IP of my modem (which was 192.168.1.1 too).
