skmax
May 19, 2020Aspirant
No boot only telnet with USB recovery
Dear all, I am writing to ask you for advice, as a last resort, before throwing away my nas. It is a 2-Bay RN102 - ReadyNAS 100, that does not start. It is not reachable from RAIDAR. I have attemp...
camilasophia6
Feb 23, 2024Aspirant
Is it staying on TS mode when USB recovery successfully rebooted the device? There might be an issue with the flash since the problem starts from booting but have you tried booting it again without the drives? If RAIDar successfully detects the NAS even when without the drives or if it is on 6.10.x it should go to safe mode or show the status as no disk inserted then there's a chance it can still be fixed.
Also, have you tried booting and doing a factory reset after you were able to access the NAs on Telnet? There might be members who can provide guide on using CLI but I would still recommend contacting Support for assistance.
HTH
