rohanzanje's avatar
rohanzanje
RBR750 Boot Loop - White Light Flashes Then Goes Dark, TFTP Recovery Failing
Device: Orbi RBR750 (Serial: 6661037RA0169, Firmware was V7.x, Purchased April 2020)
Problem: Router powers on, white light flashes for about 1 minute then all lights go off completely. Unit is in a permanent boot loop and cannot complete startup.
What I've tried:
  • Factory reset (holding reset button during white flash window)
  • TFTP firmware recovery via ethernet from Mac Studio — file RBR750-V7.2.8.5.chk — unit responds to ping at 192.168.1.3 but TFTP times out with "didn't receive answer from remote"
  • Accessed 192.168.1.1 but it routes to upstream Netgear router not Orbi
  • Tried orbilogin.com, orbilogin.local, 10.168.168.1, 192.168.1.3 — none load admin page
  • Mac internet sharing enabled (WiFi to Ethernet) to provide internet source to Orbi during recovery attempt
Current setup during recovery attempt:
  • Mac Studio ethernet → Orbi yellow WAN port
  • Mac on WiFi via backup Netgear R7000
  • Mac ethernet set to static IP 192.168.1.2
  • Orbi responds to ping consistently but web interface unreachable
Question: Is there a specific TFTP timing window or alternate recovery method for RBR750 that could help? Any known firmware corruption fix for this boot loop pattern?
  • This issue was resolved with factory reset which for some reason wasn't going through in my initial few attempts. Also with firmware update my routers pass through speed has increased 7-8x than earlier. Thank you.
  • FURRYe38's avatar
    Try a 30-30-30 reset on the RBR. IF this fails, unit maybe bad.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello rohanzanje ,
    Welcome to the NETGEAR Community!
    I understand that you have not been able to successfully use TFTP to recover your RBR750. Since the TFTP is responding to ICMP it means that there is a connection. However, there could be something else that prevents this process from being successful.
    Please follow the directions listed in the link below for additional details about the TFTP process:
    How do I upload firmware to my NETGEAR router using a TFTP client on Microsoft Windows? - NETGEAR Support
    Best,
    Kevin
    Community Team
    • FURRYe38's avatar
      Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
      Enjoy. 📡
