skmax
May 19, 2020Aspirant
No boot only telnet with USB recovery
Dear all, I am writing to ask you for advice, as a last resort, before throwing away my nas. It is a 2-Bay RN102 - ReadyNAS 100, that does not start. It is not reachable from RAIDAR. I have attemp...
camilasophia6
Feb 23, 2024Aspirant
Is it staying on TS mode when USB recovery successfully rebooted the device? There might be an issue with the flash since the problem starts from booting but have you tried booting it again without the drives? If RAIDar successfully detects the NAS even when without the drives or if it is on 6.10.x it should go to safe mode or show the status as no disk inserted then there's a chance it can still be fixed.
Also, have you tried booting and doing a factory reset after you were able to access the NAs on Telnet? There might be members who can provide guide on using CLI but I would still recommend contacting Support for assistance.
HTH
PH23-14
Feb 25, 2024Aspirant
Thanks for you suggestions. But the raidar screenshot is really the only status I can get from it.
I consider my RN102 bricked and will be looking for a replacement.
- martinr11Mar 11, 2024Aspirant
I updated the RN104 firmware with web interface to 6.10.10
After the update the device will not boot any more and says USB recovery.
I made the USB recovery memory stick as suggested by manual.
Now I am able to access the unit with telnet.
I do not know any commands for restore.
Got if fixed. I added also ReadyNASOS-6.10.10-arm.img to the memory stick. Then it did the update and shut down but still no boot.
I tried with ReadyNASOS-6.10.9-arm.img
then ReadyNASOS-6.10.8-arm.img
then ReadyNASOS-6.10.7-arm.img
After that I removed the img file from memory stick and tried again.
After that there was displayed FW update. Then with next reboot the bars progressed with staying long on 98% and the disks rattled until it finally boots to FW 6.10.10
Web interface shows Firmware 6.10.10
Files are acessible, seems that the issue is fixed.
