smahrff
Feb 02, 2019Aspirant
No IP address
Hi - I've had the RN214 set up for about a year. Haven't used it in a while. Logged on today and it says 'No IP address'. I've done a hard and soft shut down, swapped the cables, tried both LAN ports...
Feb 02, 2019Guru - Experienced User
Something a bit confusing here, since you couldn't have logged on if it had no IP address.
What is RAIDar telling you? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
Maybe post a screen shot of it's status page.
- smahrffFeb 02, 2019Aspirant
Thanks and sorry for being vague.
I logged into ReadyCloud and it says 'ReadyNAS is offline. Check power and internet connectivity'.
The ReadyNAS says 'No IP Address'.
I used RAIDar and it says "RAIDar could not find any NETGEAR storage on your network. Check that your storage device is powered on and connected correctly. For more help, visit http://my.netgear.com."
The unit is plugged in via an ethernet cable to the modem (as above I have used both ports and swapped the cable a few times but no luck). I am logged on to the Wifi presently.
- StephenBFeb 03, 2019Guru - Experienced User
Check the LEDS at the gateway (cable modem) and the NAS for activity. Also try a different port on the gateway (if you haven't done that already).
If there is no activity, and changing gateway ports doesn't help, then likely the NIC failed. I suggest checking the warranty status (should be 3 years for the original purchaser), and if you are still covered request an RMA from my.netgear.com.
