zaidon
Dec 29, 2015Aspirant
No volume exists. Some menu options are available only if a valid volume exists. RN4200,
Hi ALL... After water problem with my NAS RN4200, 32TB, I faced a corrupted software which solved by OS reinstall and restoring previously saved configuration, and another problem which is: "No vol...
- Dec 30, 2015
You could power down, remove the bad disks, put new disks in, do a factory reset (wipes all data, settings, everything) and restore your data from backup.
zaidon
Dec 30, 2015Aspirant
thank you for your answer... unfortunately I didnt have a full backup of the NAS data.. but I have a backup of the most important data...
I want to ask bout the next step regarding my NAS device hardware.. without thinking of data recovery...
should I start change the unseenable or maybe damaged disks (as shown)...
while the disks are shown healthy in the other image....
mdgm-ntgr
Dec 30, 2015NETGEAR Employee Retired
