Flash1
Mar 20, 2011Aspirant
NV+ = Segate ES.2 vs. Constellation
Howdy folks, I have an NV+ (see signature below) that currently has three drives in it: Seagate Barracuda ES.2 / ST31000340NS I'm ready to expand and add a fourth drive, however the ES.2 drives have...
mdgm-ntgr
Aug 27, 2013NETGEAR Employee Retired
The NV+ (v1 - silver chassis, runs RAIDiator 4.1.x or earlier) supports disks with capacity of up to 2TB. Higher capacity disks are incompatible. The newer Cosntellation 2TB disks probably would work but if you encounter issues with disks that are not on the compatibility list you may be denied support so do ensure you have an up to date backup.
