G_Man49
Jul 29, 2013Follower
NV + ... time to change hard drives?
I have had an Infrant / Netgear NV + for a long time. 6 years no down time! It is a 2 TB / 4 bay setup. It only came with 2 Seagate ST 3500630AS 500 Gb drives with room to grow. Now, one of the drives is down. Is the best (or only) thing to do is replace with same? I was thinking of filling up the other two bays. Is this best policy: replace with refurbish ... then copy all files to another computer ... then install 4 new compatible drives to NV+ ... to get most reliability over next few years? If so, what Seagate Model number? Has to be 500 gb I assume.
Thanks for your consideration,
Gary
Gary
1 Reply
- vandermerweMasterCould you clarify what you've got, you say a 2Tb setup but then you suggest you only have 2 drives of 500gb each? Is this in xraid or raid 1? How much capacity do you need? Is the data on the NAS still intact?
It doesn't sound like you have a backup and you are currently relying on a non - redundant volume. Is this the case.
You should have a backup of data on the NAS.
The nv+ is still a good unit if you just need storage.
You need to buy disks that match you capacity requirements. If a 500 gb volume is sufficient the get another 500 gb disk( I'm assuming you're using xraid). If you think you'll need more capacity then get bigger disks. If the volume is still intact you can add a disk, then once resync is complete you can replace the other disk with a larger one.
