flensr
Jan 11, 2015Aspirant
NV+ and Western Digital Red Pro?
I see on the hardware compatibility list that the 1TB western digital Red is supported, which makes me think that the 2TB WD Red should work. I want to go from 4 1TB drives to 4 2TB drives, to max ou...
mdgm-ntgr
Jan 11, 2015NETGEAR Employee Retired
The Red Pro should work. The Red Pro is a good drive model and a better drive than the Red.
However if you use drives outside the compatibility list you may be denied support.
Regardless of which drives you choose you should backup your data regularly. No important data should be stored on just the one device.
