xtianstratus2
Oct 04, 2019Aspirant
NV+ appears hung on disk swap
Hi - my readyNAS drives have started reporting sector errors so I decided to replace the drives. I'm installing 4 new WD10EFRXSP drives I started with drive 2 got all the proper alerts - failed d...
xtianstratus2
Thanks - I can see it on the network but can't connect to any shares.
I tried powering down via the power button but it's not responding. Is it safe to just flip the power switch in the back? - just went back to check on it and noticed it did power down on its own. I'm following the rest of your directions and will report back if I get stuck
xtianstratus2
Ok, just restarted without Drive 2 and got the following email.
Seems like I should have started with drive 4. Should I put my old drive 2 in and pull drive 4 out or does it not work like that?
ATA error count has increased in the last day.
Disk 1:
Previous count: 0
Current count: 1
Disk 3:
Previous count: 0
Current count: 1
Reallocated sector count has increased in the last day.
Disk 4:
Previous count: 0
Current count: 8824
Disk 4:
Previous count: 0
Current count: 432
Disk 4 did not pass SMART self-assessment test. Please replace this disk as soon as possible.
Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
- SandsharkOct 04, 2019Sensei
All those errors on Drive 4 were likely what was hanging the re-sync. if your shares are currently accessible, make a backup now. Drive 4 is about to die on you. Do Not try inserting another new drive to re-sync, that puts a lot mnore stress on your failing Drive 4 and may push it over the edge. You are luicky if that did not already happen.
- xtianstratus2Oct 04, 2019Aspirant
yeah - and now the errors are now over 1k. I've pulled most of the contents off the NAS and have a few things left that I'm trying to recover before it's dead.
Once that's done, I'm gong to do a rebuild with new disks.
- StephenBOct 05, 2019Guru - Experienced User
If you can't get everything, you could then attempt to reboot with the original disk 2 and not disk 4 (no harm at that point).
