oscarthecat
Nov 11, 2013Aspirant
NV+ memory upgrade
Hi, i recently bought a NV+. Is it possible to upgrade the memory with a so-dimm? Which memory should I use? Is there a how to guide? Thanks for your efforts!
Nov 11, 2013Guru - Experienced User
Do you have a v1 or a v2? Use the guide here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
