oscarthecat
Nov 11, 2013Aspirant
NV+ memory upgrade
Hi, i recently bought a NV+. Is it possible to upgrade the memory with a so-dimm? Which memory should I use? Is there a how to guide? Thanks for your efforts!
mdgm-ntgr
Nov 11, 2013NETGEAR Employee Retired
O.K. You could replace the memory (not supported). There are replacement instructions in the FAQ. Get memory that matches the specs and physical appearance of the stock module as closely as possible.
