mpatnode
Jul 31, 2011Tutor
NV+ Motherboard upgrade?
Is the motherboard in the NV+ follow any standard such that I might be able to replace it with a more recent off-the-shelf version? I'd like to get a faster Intel CPU and better network adaptor (on...
PapaBear1
Jul 31, 2011Apprentice
The mother board is of a size that will fit within the small confines of the case. Most units in the market that are ready to run RAID enclosures are proprietary to their units. They won't fit in other cases and vice versa.
If you want a GP motherboard to experiment with it will have to also have a much larger case. If you like the features of the NV+ but want a faster CPU and more memory, check out the Ultra line. I doubt that you can build one much cheaper and you would have no real support.
