mpatnode
Jul 31, 2011Tutor
NV+ Motherboard upgrade?
Is the motherboard in the NV+ follow any standard such that I might be able to replace it with a more recent off-the-shelf version? I'd like to get a faster Intel CPU and better network adaptor (on...
PapaBear1
Jul 31, 2011Apprentice
FIrst of all - the NVX has not been in production for at least 9 months. If you will check the product listing on the Netgear website you will note there are four different four bay models current. The NV+, the Ultra 4, the Ultra 4 Plus and the Pro 4. In my post said that if you wanted a faster CPU and more memory to check out the Ultra Line. The Ultra 4 uses a single core Atom D410, the Ultra 4 Plus and Pro 4 use a dual core Atom 510. The Ultras and Pros come with 1GB of memory. On Newegg the Ultra 4 (newer and faster than the NVX is $546 on Newegg, the Ultra 4 Plus is $600 and the Pro 4 is $670. Incidentally, the NVX is no longer listed on Newegg.
