tromba
May 18, 2012Aspirant
NV+ Power Supply Failure Case# 18576388
The power supply in our NV+ unit has failed. The unit was purchased new back in January 2007 and was registered on the Netgear website. According to the website the unit is no longer covered under w...
tromba
Yes, that is the post I was referring to. The unit serial number does fall within the range listed in that posting. I will keep an eye on the open support case and will be sure to let you know if there is no response. Thanks for the feedback.
