justints1
Dec 14, 2011Follower
NV+ Power Supply Failure Case#17378314
My power supply for my NV+ has died. My serial falls within the range of serials that have the reported issue with the PSU causing it to fail. I understand that there is a policy to replace these PSUs...
ReadySECURE
Dec 14, 2011Apprentice
Hi Justin,
I took a look at the case you mentioned and as of yet there is no response. I attempted to register the serial number you mention in the case, however it shows as being invalid. I have sent a reply on the case requesting a picture of the serial number so we can get the device registered properly and go from there.
