mauitim
Sep 20, 2011Follower
NV PS failure; case number 16730879
I have a ReadyNAS NV+, SN 000D-A201-47AE with a failed power supply. I purchased the unit in June of 2007. It appears that the serial number is within the range of units with "known issues." Ple...
PapaBear1
Sep 20, 2011Apprentice
Follow up with tech support since you have opened a case and posted the number. If they are not responsive, then post back. BTW - it is not considered a good idea to post your serial number in a public forum. You might want to edit that out, it will not help in this thread.
