miahz
Jan 09, 2017Aspirant
NV+ RND4000 Power Supply Failure: What are my options?
A few months ago the power supply died on my NV+ v1 (RND4250-100NAS). I tried to contact support as suggested in some other forum posts, but couldn't get anywhere with the online form – it only tells...
Jan 09, 2017Guru - Experienced User
Your system's serial number is outside the range in the service action.
There a couple of third party supplies out there, but they expensive. For instance: http://www.evercase.co.uk/CompatibilityListReadynas.htm
If you have the skills, it is possible to purchase a much less inexpensive supply, and modify the cable pinout.
Netgear support can also help you offload the data using a new X86 OS-6 ReadyNAS. More information is here: http://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6?cid=wmt_netgear_organic
- miahzJan 09, 2017Aspirant
Thanks, StephenB. I'm intertested to hear directly from Netgear, because, as i mentioned, replacement PSUs were recently sent to multiple customers whose units were also not covered by the service action. See the links i originally posted.
- StephenBJan 09, 2017Guru - Experienced User
I did see them, and hopefully Netgear will respond.
But if they don't, the options I posted are available.
- AnitaSCMar 24, 2017Aspirant
I too have a ReadyNas RND4000 that just lost power suddenly. I tested the cord and it’s good. This is really a challenge for me. Can anyone tell me if either/both of the two PSUs below will work. Of course I'd rather not buy overseas. I did find instructions for installations on the Netgear website, an old PDF, probably from when they sold parts, but no other help. Any advice would be appreciated. Thanks.
https://www.amazon.com/gp/offer-listing/B000W3X480/ref=dp_olp_new_mbc?ie=UTF8&condition=new
You can get a new replacement PSU for your readynas RND4000 here:
