zest
Jul 16, 2013Aspirant
NV+ sparc disk swap WD20EARS to WD20EFRX
Greetings, I have four WD20EARS in X-RAID. I'd like to replace with reds (unless similar $/performance/no issues can be recommended) I'd like to start with one as follows 1. power down NV+ 2. r...
mdgm-ntgr
Jul 16, 2013NETGEAR Employee Retired
So long as the capacity of the replacement disks are the same as or higher than the disks you are replacing you will be fine. If the replacement disk has less sectors then there would be a problem
