antioch
Apr 12, 2013Aspirant
NV+ stuck on Quota Check twice! (Case #20955256)
My Netgear ReadyNAS NV+ failed and went completely offline a few days ago. When I tried to restart it it got stuck doing the Quota Check at 0.9%. Following the suggestions of some postings I found...
Apr 12, 2013Guru - Experienced User
An OS reinstall will not help you if you have lost 2 drives. Sometimes cloning one of the failing drives to an error-free drive will help. Also, did you simply remove the bad drive, or replace it with a new one?
Before doing an OS reinstall I would try bypassing the volume file checks at startup. If that works, back up your system w/o delay.
Instructions for this (and OS reinstall btw) are in your hardware manual (http://www.downloads.netgear.com/files/ ... 6Dec11.pdf pages 15-16)
And here: http://www.readynas.com/kb/faq/boot/how ... _boot_menu (Duo / NV / NV+ / X6/600 section)
