jonnymorris
Mar 29, 2015Aspirant
NV+ V2 4TB Hitachi drives?
Hi, I previously only populated two of the four bays in my NV+ V2 mostly due to the cost of enterprise drives, but also because I never really needed the space. Now I think it may be time to add ...
Mar 29, 2015Guru - Experienced User
The ram is soldered on, so it cannot be upgraded.
Generally there isn't uncompressed HD footage out there, it normally is at least compressed as motion jpeg. With RAID-1 you should get ~ 50 MB/sec write speeds and ~80 MB/sec read speeds according to this old review: http://www.smallnetbuilder.com/nas/nas- ... ed?start=4
The v2 platforms have a max volume size of 16 TiB, so in RAID-1 they should be able to accept the largest drives currently available. However, there are support consequences to using drives off the HCL.
