aks
Sep 27, 2013Virtuoso
NV+ v2 Dashboard Documentation links
http://www.readynas.com/docs lands on a "Page Not Found". The "Documentation" button in the NV+ v2 dashboard previously worked, but now fails with the same error. Looks like someone removed a pa...
chirpa
Sep 28, 2013Luminary
It would likely just send you here: http://support.netgear.com/product/RND2 ... %2bv2%2429
Which has the Hardware and Software manual.
