aks
Sep 27, 2013Virtuoso
NV+ v2 Dashboard Documentation links
http://www.readynas.com/docs lands on a "Page Not Found". The "Documentation" button in the NV+ v2 dashboard previously worked, but now fails with the same error. Looks like someone removed a pa...
mdgm-ntgr
Sep 30, 2013NETGEAR Employee Retired
Fixed. If you go to http://www.readynas.com/documentation you will be redirected to support.netgear.com. From there you can choose your product and see available downloads for it such as the manuals.
