enbeekay
Aug 08, 2012Aspirant
NV+ v2 feedback...
Right well, I've just got a ReadyNAS NV+ v2 and after a bit of a false start and an RMA return (nothing to do with Netgear or the product...tried to register it only to find serial was already registe...
mdgm-ntgr
Aug 08, 2012NETGEAR Employee Retired
You can easily install nano via apt-get if you want it.
Need to an
to ensure the package list is up to date first.
In my v1 (very different hardware and different OS) my disk temperatures currently range from 40 to 46 degrees celsius. It's normal. Those disk temperatures are well within safe levels.
Need to an
# apt-get update
