chris_bick
Jan 08, 2012Aspirant
NV+ (V3) Compatibility - APC CS350 UPS
Hello All, I'm running an APC UPS (CS350) connected to an NV+ (V3) ReadyNAS. I've got the ReadyNAS all setup to monitor the UPS, which it generally does well, however every 2 weeks or so the sys...
mdgm-ntgr
Jan 08, 2012NETGEAR Employee Retired
It's definitely a NV+ v1 (RND4000-100).
The RND4000 v3 presumably indicates a few minor hardware changes since the original RND4000. It's confusing I know. Back when they labelled it RND4000 v3 they probably didn't know they would release a new product the NV+ v2 (RND4000-200)
Perhaps you should try opening a tech support (http://www.readynas.com/support) case.
