KaoticChemistry
Sep 07, 2011Aspirant
NV with 4 1.5 Seagates won't rebuild after drive swap
All, My topic pretty much sums up my problem, but here's the detail.. I've been running an NV with Seagate 1.5TBs for some years now without much issue (YEAH!), however my 4th drive has been act...
WhoCares_
Sep 07, 2011Mentor
There is a difference between what Seatools believes to be acceptable for a drive to be called "ok" and what the ReadyNAS thinks about the same drive. From my personal teesting I found that while you may have some success in trying to put the disk in until the ReadyNAS will finally accept it, the only end result will be that the NAS quite surely will trigger resyncs and rebuilds some time after. The only real solution I found was to replace drives until finally one was accepted without problems.
-Stefan
-Stefan
