au2778
Jan 13, 2016Aspirant
NV+ won't get connect to the LAN after reboot
My NV+ v2 RND4000 4-bay has been humming along for ~2 years. I had to reboot the unit recently. After which, the unit is not recognized on my simple home network anymore. All the computers and the...
BrianL2
Jan 13, 2016NETGEAR Employee Retired
Hi au2778,
Welcome to the community!
I hope you could also tell us what does the LCD screen on the front panel displays when the power button was pressed? After the unit restarted, the LCD screen will display the basic information about the device (volume space and IP address), were you able to see this?
Kind regards,
BrianL
NETGEAR Community Team
au2778
Jan 14, 2016Aspirant
Model:
ReadyNAS NV+ V2
RND4000-2000NAS
After boot up (smoothly):
192.168.1.251
C: 2.1/2.7T free
I checked my router and it sees this device and have the right IP assignment. But the comupters (Win 7 Pro, Win 10 Pro, Macbook Pro El Capitan) cannot see the NAS anymore in the network realm. Just installed the latest RAIDar 6 on the computer. It sees the NAS, it is green (healthy) and when I open the admin page. It says "The device is offline, please wait..." And it sits there with no dashboard information. I am not sure how to bring it back online.
- mdgm-ntgrJan 14, 2016NETGEAR Employee Retired
That would suggest the management service is offline.
Do you recall which services and add-ons are running on the unit?
Do you have a backup of your data?- au2778Jan 15, 2016Aspirant
The unit was pretty much default. I don't have any add-ons running on the unit. I currently don't have a backup. If I were to do it, I was hoping to remove one of the two HDs as it should be mirrored to keep as a backup. And I am not sure how to access the data directly. There has to be a better way.
