georgespiteri
Oct 30, 2013Follower
NV+v2 HCL
Drives bought on May 2012 according to the HCL published at that time of which I hold a printed copy of, included Western Digital Caviar Green WD30EZRX with a total cost of 410 Euros are now taken off...
mdgm-ntgr
Oct 30, 2013NETGEAR Employee Retired
WD no longer supports using those drives in NAS units with more than two drive bays. They have settings making them unsuitable for NAS use.
You should use WD RED disks instead.
Make sure you keep a good backup. The disks were removed for a reason. Regardless of the support situation I would recommend stopping using the WD Green disks.
