minterbrad
Aug 26, 2020Aspirant
NV+v2 repalcing a 2TB JBOD drive with 4TB builds 2TB volume
I have previously replaced 2TB JBOD drives with 3TB and 4TB in the NV+v2 without issue. Replacing a drive recently (remove /c 2TB, replace with 4TB) the new drive volume is only 2TB. It is the same...
Sandshark
Aug 30, 2020Sensei
Since each drive is a separate JBOD volume, the 8TB volume expansion limit shouldn't be coming into play, but I wonder if it is somehow. I've not done any multi-volume experiments on a V2 unit, and only have a DuoV2 on which to do so.
Via SSH, looking at the output of cat /proc/mdstat may be helpful. There may also be info in the downloaded logs .zip, which one of the Netgear Mods may help you decipher.
Since you have previously used drives >2TB, that shows you do have a real V2, so the 2TB drive size limit of the V1 is not in play.
If you do end up doing a factory reset to gain use of all drives, that should not affect the content of your USB drives.
When your message first appeared, it was locked against replies (at least from us mortals). Now that it's unlocked, maybe you'll get more.
Note to Netgear mods: The KB artical pointed to above lists hard limits for the 300, 500, and 700 series ReadyNAS that are clearly based on 4TB drives are way out of date.
minterbrad
Aug 31, 2020Aspirant
Sandshark, thanks for the pointers...here is the mdstat data. Oddly, md0 and md1 show "active raid1", whereas the box is set to RAID0. I'm not sure how to read this, so input welocme here...
root@ReadyNAS2:/# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md5 : active raid0 sdd3[0]
3902298912 blocks super 1.2 16k chunks
md4 : active raid0 sdc3[0]
2925546912 blocks super 1.2 16k chunks
md6 : active raid0 sdb3[0]
1948792880 blocks super 1.2 16k chunks
md7 : active raid0 sda3[0]
md1 : active raid1 sda2[5] sdd2[3] sdc2[2] sdb2[4]
524276 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sdc1[2] sda1[5] sdb1[4] sdd1[3]
4193268 blocks super 1.2 [4/4] [UUUU]
