SlumberJack
Oct 04, 2011Aspirant
NVX Drive failed message when spindown is enabled
I've got an NVX populated with 4 x 2T Samsung F4 drives. When I enable disk spindown the display on the NVX shows the message "Disk 3 failed", or "Disk 4 failed" As far as I can tell the disks h...
jeroen_o
Oct 27, 2011Aspirant
Hi Richard,
I've got an NVX pioneer edition populated with 4 x 2T Caviar Green WD20EARS drive
I also have the spindown feature enabled on my NVX and I also experienced the message "Disk 3 failed", AND "Disk 4 failed"
My data is also accessible, and I don't experience any performance drops.
Because I didn't knew exactly what was going on, I replaced the two disks, but the message is still showing. Then, for a moment it even showed the message the disks being dead.
I think it has something to do with the latest ,radair and/or radiator update, because before the update I didn't have this message of disk failures, and I also had the spindown enabled.
Best,
Jeroen
Best,
Jeroen
