dsloat's avatar
dsloat
Follower
Nov 08, 2013
NVX Volume C Life Support
Last night I discovered that two of the four disks (numbers 3 and 4) in my NVX have gone bad. I attempted to shut down the NVX as precaution while the replacement drives were being ordered and shipped. When I went to check on the shutdown, the power button was blinking and the display had the message "Shutting down... Vol C lifesupp!". When I checked again this morning (approximately 10 hours later), the blinking power button and shutdown message remained.
A couple of notes before the questions...
- The device is over 5 years old (so out of warranty)
- It is running 4.2.15 and X-RAID2
- Each drive is 1TB - but only 7% was used at the time of failure
- The important data is backed up in ReadyNAS Vault
And...here are the questions...
1) If the shutdown message is still there when I get home tonight, should I force the power off via the switch on the back and then attempt to restart?
2) When the replacement drives arrive, should the power be on or off when I install them (I'm assuming I need to do one drive at a time here)?
3) Should I disable backups (via vault.readynas.com) until the system is stable again?
Thanks in advance!
- Dave
1 Reply
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Life support mode indicates you need to either:
    1. Do a factory default with replacement drives installed and restore your data from backup
    2. Seek help from support to recover your data (there would likely be a fee involved for this).
    X-RAID2 single-redundancy protects against one disk failure, not two.
ProSupport for Business
