cidlockie
Aug 10, 2011Aspirant
Odd disk space behaviour
I have a ReadyNAS Duo, with two drives of 500GB each. Frontview tells me they are 88% full (407GB), but as far as I can see the files on the drives take up no more than about 200GB.
The second drive is a backup of the first, added after the original. I understand that this does not mean I should expect 1TB of space, but two drives with identical data and a total of 500GB (or a bit below) that I can actually use. This doesn't explain however why Frontview is giving the disk space used as twice what I actually believe it to be.
The reason I need to know this is because, believing Frontview, I've just gone and bought 2 x 2TB drives (from the compatible hardware list) as I've assumed the two here are nearly full. Is there some way to work out what's going on here?
I'm sorry if this has been dealt with before, I can't find an equivalent topic via search. There's something to do with "X-RAID" that may be relevant but it's Greek to me.
Thanks.
Thanks.
- cidlockieAspirantBy the way, to the best of my knowledge I have installed no applications or third-party software or anything like that on these drives. I have used it to store music files, and nothing else.
- cidlockieAspirantCan anyone help me out with this? Still don't know what the hell is going on.
- PapaBear1ApprenticeThere can be many reasons for this. The file structure use 16K blocks, so each file or part of a file will occupy a minimum of 16K no matter how small the file. If the file is 16,385 Bytes, then it will take two blocks (since it is 1 Byte over the 16,384) or 32,770 Bytes and be reported as 33 K even though windows reports it as 16K. If you are using Windows Vista or Windows 7 the thumbnails used to display the files also will take up space, but not show up in the directory.
Two 500GB drives in X-Raid will give you a redundant volume of around 462GB (Converting 500GB with the 1000/1024 byte conversion gives approx 488 less the 26 GB for overhead gives 462). As to why the volume shows up as 407GB used, if you list all the files and sizes, the file size on disk will be in blocks of 16,384 Bytes not the 512 Bytes found on a PC disk. Then there are the hidden files on the disk. Windows Vista and Windows 7 stores thumbnails in the same folder as the file with which it is associated. These are hidden files and do not show up in listings. While they are generally small files, each one will take up another 16,384 bytes minimum.
When I had a 500GB volume on my NV+ (2 x 500GB drives as you have), I used to try to figure it out and finally gave up. The ability to use larger drives and larger volumes and the newer operating system are just going to take disk space. I would just update to the 2x2TB drives you have and enjoy the additional space.
Don't forget to update your backup before you start swapping drives (of course you have a backup) just in case something goes wrong. Murphy is always lurking. - cidlockieAspirantWhat confuses me is I've copied all the files to my PC's internal drive and the resulting directory is less than 200GB. Just because it's a different drive I can't see why it would claim it takes up more space for the exact same set of files.
But never mind, I'll just upgrade to the bigger the drives as you suggest (and hope it doesn't immediately tell me there is 1.8TB of space used up already...)
Thanks PapaBear. - yank1AspirantFYI, I have a DUO as well (2x 1.5TB), and I have also a lot of incoherency:
- the frontview pretends I'm using 1395GB of the 1395GB
- appleShare protocol says I'm using 886GB on the 1.49TB
- df on the server shows a single /dev/hdc1 where 1.5GB are used on the 1.9GB available
From what I see, I have no trouble using the NAS for what it is supposed to be made for. But I feel rather insecure with those kind of unaccurate information.
Good Luck.
Yank
