Bent82
Jan 06, 2014Guide
Old NV: Known Good Fan Not Working
I have an old NV that we had been using for about 7 years or so. I have at one point replaced the power supply, and just a few months ago had to replace a seized fan. I found the exact same model th...
Bent82
Jan 07, 2014Guide
I guess I haven't, but was assuming it is working since the only thing I have that isn't working on the system is the fan. I would think that a fan wouldn't draw more than the 4 hard drives. Nothing else behaves like a bad power supply. If you have a way for me to check the PSU, I can try it.
