Bent82
Jan 06, 2014Guide
Old NV: Known Good Fan Not Working
I have an old NV that we had been using for about 7 years or so. I have at one point replaced the power supply, and just a few months ago had to replace a seized fan. I found the exact same model th...
mdgm-ntgr
Jan 07, 2014NETGEAR Employee Retired
Remove the PSU as per the power supply replacement instructions in the FAQ and check for burnt capacitors.
