Klanivo's avatar
Klanivo
Follower
Mar 18, 2024
old ReadyNAS Duo Ver2
Zdravím vás, dlho som bol mimo domova a nepoužil som svoje ReadyNas Duo 2011. Keď ho chcem pripojiť, zobrazí sa hlásenie: "Server 192.168.0.66 používa nepodporovaný protokol". Zabudol som, ako ho pripojiť lokálne k NB, môžete mi prosím poradiť zmeniť protokol. Vopred ďakujem, Ivan
1 Reply
  • StephenB's avatar
    First, it would be useful to confirm the version.
    The original Duo is called the v1 here.  It
    • runs 4.1.x firmware
    • says ReadyNAS Duo on the front panel
    There can be other labels that say v2, which should be ignored.
    The Duo v2
    • runs 5.3.x firmware
    • says ReadyNAS Duo v2 on the front panel
    Either way, if the error you are getting is when you try to access the web ui, then the simplest option is to switch to FireFox. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
    If the error is when you try to access the shares with Windows Explorer, then go into "turn windows features on or off" and enable the SMB 1/CIFs client on the PC.
ProSupport for Business
