sesailor
Jun 16, 2019Aspirant
Old Readynas rnd4000 with new psu
I had an old rnd4000 with 4 disks where the power supply unit had broken. So I replaced it with a new one. Now the rnd4000 first boots with a rapid blinking which after approx 20 seconds will be slo...
Jun 16, 2019Guru - Experienced User
Did you make the needed pinout change? (Or purchase a PSU that already had that change applied)?
- sesailorJun 16, 2019Aspirant
I bought a psu that already had the pinout changed. The unit just says 'Booting' and thr power on button flashes. When I remove the disk, the display shows 'no disks' and 'Booting'
This is the replacement: https://www.overtek.co.uk/products/netgear-readynas-power-supply-psu-replacement
- StephenBJun 16, 2019Guru - Experienced User
Do you have a spare disk you can use? If so, try doing a fresh factory install with only that disk in place.
I did that, Now the lcd shows..Booting. Waiting for Raidar.
According to the manual I found ithe nas should have192.168.168.168 so I defined the ethernet of my computer as 192.168.168.2 conneced a lancable but Raidar doesnot find the nas. This is not my nas so I have asked the owner if he can find a manual...It could be the wrong subnet. I could perhaps use a sniffer to see the adress of the nas.
