jeepxtreme
Jun 21, 2017Aspirant
olderversion of USB RECOVERY TOOL needed
Hello! After a turning off my NAS, it would not come up again. Blinking Power LED for some time and than it goes dark. Hooking up a monitor shows a kernel panic. After a while i was abel to fix...
Ki_Adi_Mundi
Jun 25, 2017NETGEAR Employee Retired
Hi jeepxtreme,
There is not much big change for usb recovery tools(most changes is to support new models), so the old version tools doesn't help for your case either.
if you have a bootable rufus with syslinux as bootloder( rufus can make bootable drive by syslinux), you can just copy all files from usbrecovery.v2.0.R15-T3/x86 to the usb, I think that should work.
BTW, you can ignore the "gpio_it87: Unknown Chip found, Chip 8721 Revision 4", that's just a warning. when usb recovery done, box will be powered up automatically.
