rille111
Sep 09, 2013Aspirant
One disk crashed, then another shortly after.
Specs: Model: ReadyNAS NV+ Radiator: ? RAID Type: ? - The propriety raid system that the NV+ has Number of drives: 4 Drive Size: 1TB*4 Drive Manufacturer: wd caviar green wd10ears Drive Model: ...
mangrove
Sep 15, 2013Apprentice
I have been asked to provide details on my recovery procedure... unfortunately, since you used X-Raid 2 (which is LVM), the software I used won't work for you as it doesn't support LVM. :( Bummer. Will provide details anyway.
Basically, I finally used the R-Studio software from R-Tools Technology after several failed attempts assembling the array in Linux, trying to resync it, using Testdisk, etc. I attached three of the hard drives with SATA-to-USB adapters (do note, SATA will be MUCH faster but at the time I did not have access to a recovery workstation with enough SATA ports) and instructed the software to reconstruct the array with one missing disk -- it simulates the missing disk and recalculates data from the remaining disks on-the-fly, this is useful if one of your disks hangs for example. You can input different RAID parameters, then just choose your geometry and preview the disks. It supports EXTx out-of-box, and to verify that your settings are correct, try extracting a fairly large file and have a look at it, with a video clip, image or a zip you will immediately notice if anything is broken.
Try finding software that will work with LVM. Most recovery software have a free trial mode. Work from images/mirrors of the original disks if at all possible.
I found using Linux to recreate the array pretty useless, as the array would drop immediately on any error. Only software that actually ignores if the array is broken or not will work. Then again, it might be possible to do it in some way I didn't found out. :)
