Ronbon24
Jan 07, 2020Aspirant
Only fan spinning no Lcd
My wife decided to paint my office and unplugged my readynas nvx for 2 days. When she plugged it back in, the fan spins on high but no lcd or any other lights come on. I notice an amber light on the...
Jan 08, 2020Guru - Experienced User
Was it properly shut down, or did she just pull the plug?
Ronbon24 wrote:
When she plugged it back in, the fan spins on high but no lcd or any other lights come on. I cannot discover readynas using Raidar.
Try removing powering down, and remove the disks (labeling by slot). Then power it up, and see if you get something on the LCD or in RAIDar.
Ronbon24
Jan 08, 2020Aspirant
She just pulled the plug. I have removed and labelled the drives and it still just powers on with the fan spinning on high. Holding the power button will turn it off, but it won't connect to my network and the lcd never come on.
Thanks
- StephenBJan 08, 2020Guru - Experienced User
Ok. So something obviously failed - not sure if it is one of the the power supply outputs or the system board. Perhaps Sandshark can offer an informed guess.
I think it is pretty likely that the RAID array is intact. Are you going to need to off-load data?
One option is to get a new OS-6 x86 ReadyNAS (RN300 series or better). While you can't simply migrate the disks, you can temporaily mount the data volume so you can off-load it. There is some information on that here: https://kb.netgear.com/29957/ReadyNAS-Migrating-disks-from-RAIDiator-4-2-to-ReadyNAS-OS-6-x86
- Ronbon24Jan 08, 2020Aspirant
Problem solved. Changed the battery on the motherboard and it booted normally and all drives intact.
- StephenBJan 09, 2020Guru - Experienced User
That's odd, since the battery is really there just to keep the real time clock running. But its great that it came back to life, whatever the reason.
It is a very old platform of course, so you probably should plan on replacing it at some point.
