leftkoyl
Apr 05, 2019Aspirant
Open vulnerabilites for RN10400
QID
Title
Severity
70003
Null Session/Password NetBIOS Access
4
45003
Remote User List Disclosure Using NetBIOS
4
How can we close this open vulnerabili...
Apr 05, 2019Guru - Experienced User
- What firmware are you running?
- Have you disabled anonymous access on your network shares?
- what security scanning tool is reporting these vulnerabilities?
leftkoyl
Apr 08, 2019Aspirant
I have update to 6.10 previous week.
1) 6.9.4
2) Yes guest and everyone user are not active
3) Qualys Guard
- SandsharkApr 11, 2019Sensei
1) 6.9.4
3) Qualys Guard
First two lines seem contradictory. Which OS version was running when you ran the scan? Have you tried again after updating to 6.10.0, which does bump the SMB version.
#2 is not the same thing as disabling anonymous access. See checkbox at the bottom of "Network Access" tab for the share. Or, you can do it across the board by installing SMB plus and disabling anonymous on the Security tab.
