techymechy's avatar
techymechy
Orbi RBK760 with two satellites: What is the best NAS?
I have an Orbi RBK760 with two satellites that I bought from Costco.   I want to set up a NAS for auto back up of a desk top PC that is connected to the Orbi router via CAT cable and Windows laptops and Mac laptops (laptops via wireless).
* How does one do this?  Is there a step by step description that a 5 year old could understand?
* What is the recommended NAS for this purpose?   I don't think I'll ever need over 10-12 Tb of information.  I would like to have at least a two bay device so I can run RAID mirrored drives.
I see a used Synology DS416 that is for sale locally that I could get for a good price, but it is probably 5 years old and I'm concerned about the software compatibility with my ORBI.   I might just bite the bullet and buy a new two drive system.
another potential local used NAS is:
https://www.westerndigital.com/products/network-attached-storage/wd-my-cloud-pro-series-pr4100?sku=WDBNFA0240KBK-NESN
Please help me get the right NAS so it can have up to 10 Tb capacity, do daily updates, and can update the CAT wired PC through the ORBI router as well as do wireless backups to MAC and Windows PC's.
Thanks!
  • StephenB's avatar
    Generally I think it's best to run the backup software itself on the PC.  There are several packages that can be set up to run on schedule (including powering up the PC if necessary) and back up the PC to a network share.  One of several is FreeFileSync (which as the name implies, is free).
    Another factor to consider is disaster recovery - preserving data even if there is theft, fire, flood, ransomware attack, etc.  While I do back up my data locally (I have more than one NAS), I also use cloud backup.  You don't need to back up everything to the cloud, but it would be good to put any personal records (documents, photos, videos) that can't be replaced in cloud storage as well as local backup.
    Another approach to disaster recovery is to keep a copy of the backup in another location. If you are disciplined enough, you can copy the data to a USB drive, and arrange with a friend or family member to keep a copy of the data in their home - or use a safety deposit box if you have one.  You'd then need to regularly update that copy.
    It is also possible to set up a NAS in a remote location, and back up to that NAS.  That would require a more advanced setup, so that might require more tech knowledge than you have right now.
    ReadyNAS is of course one possibility.  But Netgear is clearly exiting their NAS business - anything you purchase would be used, and be unsupported.  So likely not the best choice.
    If I were looking for a new NAS now, I would be looking at these three brands first.
    • Asustor
    • QNAP
    • Synology
    These are listed alphabetically - I am not recommending one over the others, just trying to give you a starting point.
    The WD myDrive Pro system you linked in is also worth considering - it might be simpler to set up and administer than the models I'd be interested in.  If you haven't reviewed its manual, you can find it here:
    A NAS isn't a "set up and forget" device.  You will need to learn the basics of how it works, and monitor it regularly for errors (disk failures, etc).  You might want to download the manuals for the models you are considering, and read through them before purchase.
    If you do decide to consider ReadyNAS, the software manual is here:
    That is not a concern.  Any NAS will be compatible with your Orbi.  They are basically specialized PCs (running linux instead of Windows), and just need the same basic routing services that your desktop PCs use.
    You can find new basic 2-bay diskless NAS suitable for backup for about $200-$300 USD.  Two 12 TB Ironwolf or Red Plus drives are suitable choices, and would cost about $250 each. So a completely new system would cost you $700-$800.
    Used models are definitely cheaper, but it is worth looking into the vendor's support policies.  Netgear (for example) did not provide any support at all for used NAS - and their warranty is not transferrable.  No idea on the others.
    Also, some users here have purchased used ReadyNAS that either didn't work properly or were missing some needed parts (usually drive trays, or screws for the drives).  So definitely something to be careful about.
    • Sandshark's avatar
      Sandshark
      Sensei
      Given your concern regarding compatibility with the router, I just want to verify that you are looking for a NAS, which connects to your network via Ethernet, and not something that connects to the Orbi via USB.  Many routers have some basic NAS-like functionality with USB-connected drives, which may be what you are really wanting.
      • techymechy's avatar
        techymechy
        Thanks so much for the replies.
        To be more clear, this is what I was envisioning:
        1.  My desktop is connected to my ORBI base switch via CAT cable.   My internet modem is also connected to my Orbi Switch.
        2. I will have both Windows and Mac Laptops which use the ORBI wireless around the house.
        3. I would like to get a NAS that will be connected to the ORBI switch via CAT cable.   This NAS will allow daily updates from the CAT wired desktop and the laptops.
        I read somewhere that the ORBI will not allow a NAS to have daily updates via wireless connection for laptops (both windows and Mac).
        I don't know if this is a function of the NAS, the software being used on the NAS/desktop/laptop computers or the ORBI.
        I really like my ORBI for the coverage and speed, but I didn't look into setting this up for a NAS.
        I am thinking I'll buy a new NAS, probably 2 bay with a mirrored drive.   I have a external 3 Tb drive that is used for manual backups, but I only do it once per quarter.   I really need to be more disciplined for getting updates on a daily basis.
        Do you have a recommendation for a great NAS for my purpose?   I can't see myself ever using this device for file sharing or streaming DVD's, etc.   I just want it for data back-up.
ProSupport for Business
