80sKid
Feb 22, 2023Aspirant
Pair of disks formerly used in RN202-100NES, using newer hardware
In 2016/2017 I had a ReadyNAS RN202-100NES. The ReadyNAS itself stopped working and I removed the drives. I now need to access the drives, (I believe these were in a mirror). My plan was to jump ...
- Mar 25, 2023
2.5mm x 5.5mm or 2.1mm x 5.5mm will work. It's the typical connector for that type of supply.
80sKid
Amazing! Thank you!
Do you know if the Netgear ReadyNAS Duo's use OS-6 ? Like the RND2110 ?
