80sKid
Feb 22, 2023Aspirant
Pair of disks formerly used in RN202-100NES, using newer hardware
In 2016/2017 I had a ReadyNAS RN202-100NES. The ReadyNAS itself stopped working and I removed the drives. I now need to access the drives, (I believe these were in a mirror). My plan was to jump ...
- Mar 25, 2023
2.5mm x 5.5mm or 2.1mm x 5.5mm will work. It's the typical connector for that type of supply.
Feb 22, 2023Guru - Experienced User
80sKid wrote:
Will any other ReadyNAS read these drives I have?
You can migrate to any other OS-6 readynas (RN1xx, RN2xx, RN3xx, RN4xx, RN5xx, RN6xx). Lower model numbers will be less expensive. With these, you can simply plug in the drives and boot up. If you are certain you were using XRAID or RAID-1 (the default), you could just insert one, just to be extra safe.
Other legacy NAS can also be converted to OS-6 - that includes the Ultra and Pro models. Those would need to be converted before you insert the RN202 disks, and you would need a spare disk to do that.
If you can connect one of the disks to a Windows PC (using SATA or a USB adapter/dock) then you could try this software:
Note I haven't used it myself, so I don't know if it will work.
80sKid
Mar 24, 2023Aspirant
Hi! I found a RN10200-100EUS on Ebay (UK), but it's missing a Power Supply.
I believe I need a 12V, 5A 60W: input 100-240V AC, 50/60Hz, but I can't tell from the data sheet what the barrel size is of the power jack plug that goes into the unit?
TIA
- SandsharkMar 25, 2023Sensei
