80sKid
Feb 22, 2023Aspirant
Pair of disks formerly used in RN202-100NES, using newer hardware
In 2016/2017 I had a ReadyNAS RN202-100NES. The ReadyNAS itself stopped working and I removed the drives. I now need to access the drives, (I believe these were in a mirror). My plan was to jump ...
- Mar 25, 2023
2.5mm x 5.5mm or 2.1mm x 5.5mm will work. It's the typical connector for that type of supply.
80sKid
Mar 24, 2023Aspirant
Hi! I found a RN10200-100EUS on Ebay (UK), but it's missing a Power Supply.
I believe I need a 12V, 5A 60W: input 100-240V AC, 50/60Hz, but I can't tell from the data sheet what the barrel size is of the power jack plug that goes into the unit?
TIA
Sandshark
Mar 25, 2023Sensei
